跳转到主内容
Sony Cyber-shot DSC-WX100 Lens Assembly Replacement
你所需要的
  1. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 2 中的图像 1,1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Outer Casing: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Outer Casing: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Outer Casing: 步骤 3 中的图像 3,3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to gently release the two indicated tabs.
    • Pull up on the lower end of the plate. Lift it so that the plate is uninhibited by the indicated bump.
    • Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
    • For help with this step, refer to the video.
  6. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 7 中的图像 1,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 7 中的图像 2,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 7 中的图像 3,3
    • Remove this screw (1mm) with the Phillips #000 Screwdriver.
    • Gently lift the LCD screen component from the metal plate.
    • Remove the metal plate that was underneath the LCD screen from the camera.
  7. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 8 中的图像 1,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 8 中的图像 2,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 8 中的图像 3,3
    • Peel back the copper sheet.
    • Unscrew the three marked screws (2mm) using a Phillips #000 Screwdriver.
    • Remove the panel attached by said screws.
  8. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 9 中的图像 1,1
    • Peel back both the copper sheet and the black tape underneath the panel to expose the connection port.
  9. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 10 中的图像 1,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 10 中的图像 2,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 10 中的图像 3,3
    • Use a plastic opening tool to pry the black bar upwards.
    • Pull the image sensor out after the black tab is released.
  10. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Lens Assembly: 步骤 11 中的图像 1,1
    • Peel back the black tape to reveal the connection port shown below.
  11. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 12 中的图像 1,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 12 中的图像 2,3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 步骤 12 中的图像 3,3
    • Pry the black bar upwards with a plastic opening tool.
    • Remove the wire sheet from the connection port.
结论
Matthew
于03/18/15注册
583 声望
创作了4篇指南
团队
Michigan Tech, Team 1-9, Lauer Spring 2015 Michigan Tech, Team 1-9, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G9
2 名成员
创作了6篇指南
一条评论
could i also replace the lens of my wx220 using these instructions?
Vinicius Lupas - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 1,529
