跳转到主内容
Sony Cyber-shot DSC-W800 Button Board Replacement
你所需要的
  1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: 步骤 1 中的图像 3,3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Button Board Replacement: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-W800 Button Board Replacement: 步骤 2 中的图像 2,2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Button Board Replacement: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-W800 Button Board Replacement: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-W800 Button Board Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
结论
3等其他人完成本指南。
Thomas Campo
于02/09/16注册
809 声望
创作了4篇指南
团队
USF Tampa, Team 17-5, Blackwell Winter 2016 USF Tampa, Team 17-5, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G5
5 名成员
创作了5篇指南
4条评论
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - 回复
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - 回复
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
Naveed Shoukat - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 45
总计 2,485
