跳转到主内容
Sony Cyber-shot DSC-W730 Mother Board Replacement
你所需要的
  1. Sony Cyber-shot DSC-W730 Mother Board Replacement, Removing the Case: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-W730 Mother Board Replacement, Removing the Case: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-W730 Mother Board Replacement, Removing the Case: 步骤 1 中的图像 3,3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 2 中的图像 1,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 2 中的图像 2,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 2 中的图像 3,3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 3 中的图像 2,2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 4 中的图像 2,2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 5 中的图像 3,3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 Mother Board Replacement, LCD Control Board: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-W730 Mother Board Replacement, LCD Control Board: 步骤 6 中的图像 2,2
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  7. Sony Cyber-shot DSC-W730 Mother Board Replacement, LCD Screen: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-W730 Mother Board Replacement, LCD Screen: 步骤 7 中的图像 2,2
    • Use tweezers to remove the ribbon that is connected from the LCD screen to the camera by pulling the part that is folded under, out.
  8. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 8 中的图像 2,2
    • Slide the right side of the LCD screen clockwise, which will push it off the camera. The rest of the screen should come off with it with ease.
  9. Sony Cyber-shot DSC-W730 Mother Board Replacement, Mother Board: 步骤 9 中的图像 1,3 Sony Cyber-shot DSC-W730 Mother Board Replacement, Mother Board: 步骤 9 中的图像 2,3 Sony Cyber-shot DSC-W730 Mother Board Replacement, Mother Board: 步骤 9 中的图像 3,3
    • After the screen is off, work the spudger under three clips to remove the metal plate.
  10. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 10 中的图像 1,2 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 10 中的图像 2,2
    • After the clips are disengaged, lift off the metal cover.
  11. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 11 中的图像 1,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 11 中的图像 2,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 11 中的图像 3,3
    • Use the spudger and disengage the black plastic clip located on the bottom right of the camera facing the lens.
  12. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 12 中的图像 1,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 12 中的图像 2,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 12 中的图像 3,3
    • Flip the camera over, facing the bottom of the camera towards you. Then use the spudger to detach the plastic clip on the right, near where the LCD control board was.
  13. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 13 中的图像 1,1
    • Use the spudger and slide the plastic case over the mini USB port.
  14. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 14 中的图像 1,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 14 中的图像 2,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 14 中的图像 3,3
    • Use the spudger to disengage the plastic clip on the top of the camera.
  15. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 15 中的图像 1,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 15 中的图像 2,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 15 中的图像 3,3
    • Use the spudger and seperate each end of the metal piece. Once the speaker is free you can lift off the plastic frame.
  16. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 16 中的图像 1,2 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 16 中的图像 2,2
    • Use tweezers to disconnect the ribbon located under the motherboard near the bottom of the camera.
  17. Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 17 中的图像 1,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 17 中的图像 2,3 Sony Cyber-shot DSC-W730 Mother Board Replacement: 步骤 17 中的图像 3,3
    • Now with one hand located on the plastic skeleton and the other on the motherboard pull the motherboard to the left to disconnect the last ribbon.
结论
另外一个人完成了本指南。
Douglas Howe
于01/08/15注册
510 声望
创作了4篇指南
团队
USF Tampa, Team 9-4, Blackwell Winter 2015 USF Tampa, Team 9-4, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 19
总计 1,073
