跳转到主内容
Sony Cyber-shot DSC-W730 LCD Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: 步骤 1 中的图像 3,3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 2 中的图像 1,3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 2 中的图像 2,3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  7. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the ribbon that is connected from the LCD screen to the camera by pulling the part that is folded under, out.
  8. Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-W730 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Slide the right side of the LCD screen clockwise, which will push it off the camera. The rest of the screen should come off with it with ease.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 9-4, Blackwell Winter 2015 USF Tampa, Team 9-4, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G4
3 名成员
创作了12篇指南
2指南评论
Excellent tutorial. It helped me a lot. I ve just replaced my LCD with success.
Thank you
joao - 回复
I can record with the camera but I can't see the image while taking photos. Any suggestions?
Robin_o - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 53
总计 1,916
