跳转到主内容
Sony Cyber-shot DSC-W730 Flash Control Board Replacement
你所需要的
  1. Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Removing the Case: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Removing the Case: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Removing the Case: 步骤 1 中的图像 3,3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 2 中的图像 1,3 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 2 中的图像 2,3 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 2 中的图像 3,3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 3 中的图像 2,2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 4 中的图像 2,2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 5 中的图像 3,3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 Flash Control Board Replacement, LCD Control Board: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, LCD Control Board: 步骤 6 中的图像 2,2
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  7. Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Caption/Flash Control Board: 步骤 7 中的图像 1,3 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Caption/Flash Control Board: 步骤 7 中的图像 2,3 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Caption/Flash Control Board: 步骤 7 中的图像 3,3
    • Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected.
  8. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 步骤 8 中的图像 1,1
    • Once you have removed the piece this is what it will look like.
结论
Douglas Howe
于01/08/15注册
510 声望
创作了4篇指南
团队
USF Tampa, Team 9-4, Blackwell Winter 2015 USF Tampa, Team 9-4, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 717
