跳转到主内容
Sony Cyber-shot DSC-W570 Flash Replacement
你所需要的
  1. Sony Cyber-shot DSC-W570 Flash Replacement, Case Cover: 步骤 1 中的图像 1,1
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 2 中的图像 1,1
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 3 中的图像 1,1
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 4 中的图像 2,2
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 5 中的图像 2,2
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
  6. Sony Cyber-shot DSC-W570 Flash Replacement, LCD Screen: 步骤 6 中的图像 1,1
    • These are the two cables connecting the LCD screen to the motherboard below the screen.
  7. Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 7 中的图像 1,1
    • Remove the LCD screen from the side opppsite the battery terminals. Watch for the two cords mentioned in the previous step. These will still be connected.The side will flip up as shown in the next step.
  8. Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 8 中的图像 1,1
    • Pull these two cords straight back to disconnect them from the respective housings. Caution: The housing do not need to be moved or adjusted in anyway. Do not pull the cords at an angle, it can destroy the cords and the housing. Pull Straight Back!
  9. Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 9 中的图像 1,1
    • This is what the camera should look like after 2 cords and the screen have been removed. The lens cord is being held to the side for a clearer view.
  10. Sony Cyber-shot DSC-W570 Flash Replacement, Flash: 步骤 10 中的图像 1,1
    • These are buttons for menu. Be sure to check that the flash settings are correct for your scene. Do not replace flash until settings are verified.
  11. Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 11 中的图像 1,2 Sony Cyber-shot DSC-W570 Flash Replacement: 步骤 11 中的图像 2,2
    • Caution: Touching the capacitor wires may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • After camera is disassembled the capacitor will need to be removed. Ribbons are gently pulled away from connector.
结论
2等其他人完成本指南。
Kenneth
于01/21/15注册
174 声望
撰写一个指南
团队
USF Tampa, Team 9-1, Brown Winter 2015 USF Tampa, Team 9-1, Brown Winter 2015 的会员
USFT-BROWN-W15S9G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 605
