跳转到主内容
Sony Cyber-shot DSC-W570 Case Cover Replacement
你所需要的
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: 步骤 1 中的图像 1,1
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: 步骤 2 中的图像 1,1
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: 步骤 3 中的图像 1,1
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W570 Case Cover Replacement: 步骤 4 中的图像 2,2
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-W570 Case Cover Replacement: 步骤 5 中的图像 2,2
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
结论
另外一个人完成了本指南。
Zizheng Su
于01/21/15注册
101 声望
撰写一个指南
团队
USF Tampa, Team 9-1, Brown Winter 2015 USF Tampa, Team 9-1, Brown Winter 2015 的会员
USFT-BROWN-W15S9G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 698
