跳转到主内容
Sony Cyber-shot DSC-W55 Lens Replacement
你所需要的
  1. Sony Cyber-shot DSC-W55 Lens Replacement, Battery: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-W55 Lens Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 2 中的图像 2,2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: 步骤 3 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 4 中的图像 2,2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
    • Remove the panel.
  5. Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 5 中的图像 1,1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 6 中的图像 2,2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 Lens Replacement, Front Case: 步骤 7 中的图像 1,1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 8 中的图像 1,3 Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 8 中的图像 2,3 Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 8 中的图像 3,3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Lens Replacement, Lens: 步骤 9 中的图像 1,2 Sony Cyber-shot DSC-W55 Lens Replacement, Lens: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 10 中的图像 1,2 Sony Cyber-shot DSC-W55 Lens Replacement: 步骤 10 中的图像 2,2
    • Gently pull the lens container out of the camera.
结论
15等其他人完成本指南。
kkfong91
于10/11/10注册
350 声望
创作了2篇指南
团队
Cal Poly, Team 9-20, Regan Fall 2010 Cal Poly, Team 9-20, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G20
5 名成员
创作了20篇指南
4指南评论
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Erwann Robin - 回复
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
agnelobarretto - 回复
my lens is broken/ stuck. Please let me know if you know where i can buy a replacement for it
mariana larenas - 回复
Where can i find these len?
Beatriz - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 157
总计 24,581
