跳转到主内容
Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement
你所需要的
  1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Place the Sony Cyber-shot DSC-W510 on the magnetic project mat. This will help keep the small screws organized.
  2. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: 步骤 2 中的图像 2,2
    • Using the Phillips #00 screwdriver, unscrew the outside screws from the frame of the camera.
    • There are five screws on the bottom of the camera and two on the side.
    • If the screws are stripped, visit the Removing a Stripped Screw Guide.
  3. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 3 中的图像 2,2
    • Pry open the screen frame using a plastic opening tool.
    • It may be necessary to start by prying at one end of the screen and moving around the edge of the screen frame, until it pops out.
  4. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 4 中的图像 2,2
    • Using the screw driver, unscrew the one screw on the control panel board.
  5. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 5 中的图像 1,1
    • Gently unplug the control panel from the motherboard outlet.
  6. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 6 中的图像 2,2
    • Using your hands, pry open the LCD screen from the metal board.
    • Gently unplug the LCD screen from the motherboard.
  7. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: 步骤 7 中的图像 2,2
    • Remove the screws from the metal board using the Phillips #00 screwdriver.
    • Pop apart the metal board using the plastic opening tool.
    • Peel apart the black tape from the flash bulb.
    • Avoid touching the bulb as it will burn or shock if touched.
  8. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 8 中的图像 1,3 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 8 中的图像 2,3 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 8 中的图像 3,3
    • Pry open the remaining covers of the camera using the plastic opening tool.
    • Some parts may fall out during this process.
  9. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 9 中的图像 1,1
    • Unscrew the one screw from the motherboard.
    • Disconnect the two links from the camera unit to the motherboard.
  10. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: 步骤 10 中的图像 1,1
    • Pop out the lens zoom unit from the frame by using either your thumb or an opening tool.
结论
4等其他人完成本指南。
kyle
于02/05/15注册
424 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 1,276
