当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Remove the single visible screw from both sides of the camera.
Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
Do NOT remove all four screws from the bottom.
Gently remove the back cover from the camera.
The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
Detach the orange cable from the board.
Use a thin object, like a paperclip, to gently pry the cable off the connector.
The LCD screen sits in two slots; one on the bottom, and one on the left edge.
Slide LCD screen from the two slots.
Do not attempt to completely remove the screen, as it is still attached to the camera.
To remove the LCD screen, detach the orange cable from the board.
If needed, replace the LCD screen.
Disconnect the flash cable (black and white wires) before completely removing the front case.
Gently start to remove the case.
Once the cable is free, set aside the front case.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
