简介
Disassembling Sony Cybershot DSC-W5 in order to get to the battery terminal so that it can be replaced.
你所需要的
Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
Remove both batteries.
Remove the two screws holding the circuit board down.
Now remove the plastic plate that covers the motherboard.
Below and to the left of the viewfinder there is a vertical slot in the motherboard with a soldered connection to the flash capacitor on each side. Using a small screwdriver with an INSULATED handle, short these together for several seconds to discharge the potentially dangerous charge.
Disconnect the flash cable (black and white wires) before completely removing the front case.
Gently start to remove the case.
Once the cable is free, set aside the front case.
If the front doesn't seem to want to come away, maybe the flash cable is caught around its socket.
Remove the orange cable connecting the battery terminal to the motherboard.
5等其他人完成本指南。
一条评论
Clean the little nobs in the pattery-pack and problem solved! I also removed the black plastic ring that was on the +pole inside.
