跳转到主内容
Sony Cyber-shot DSC-W5 battery compartment replacement
你所需要的
  1. Sony Cyber-shot DSC-W5 battery compartment replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 2 中的图像 2,2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 3 中的图像 2,2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 battery compartment replacement, LCD Screen: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement, LCD Screen: 步骤 4 中的图像 2,2
    • Remove the two screws holding the circuit board down.
    what to do if i cannot remove the screws
    aarushi salunkhe - 回复
  5. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 5 中的图像 1,1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 6 中的图像 2,2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 7 中的图像 1,3 Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 7 中的图像 2,3 Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 7 中的图像 3,3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
  8. Sony Cyber-shot DSC-W5 battery compartment replacement, Speaker: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement, Speaker: 步骤 8 中的图像 2,2
    • Remove the two screws holding down the steel back plate.
    • Remove steel back plate.
  9. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 9 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 9 中的图像 2,2
    • Now remove the plastic plate that covers the motherboard.
    Below and to the left of the viewfinder there is a vertical slot in the motherboard with a soldered connection to the flash capacitor on each side. Using a small screwdriver with an INSULATED handle, short these together for several seconds to discharge the potentially dangerous charge.
    Philip Le Riche - 回复
  10. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 10 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 10 中的图像 2,2
    • Warning: Electric Shock From this point on, hold the camera by the chrome edges ONLY. Capacitors store electric charge even if the batteries are removed.
    • Remove the blue cable.
  11. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 11 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 11 中的图像 2,2
    • Disconnect the flash cable (black and white wires) before completely removing the front case.
    • Gently start to remove the case.
    • Once the cable is free, set aside the front case.
    If the front doesn't seem to want to come away, maybe the flash cable is caught around its socket.
  12. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 12 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 12 中的图像 2,2
    • The speaker should now be clearly seen on the underside of the camera.
    • Gently unplug the speaker from the motherboard.
    • Replace the speaker.
  13. Sony Cyber-shot DSC-W5 battery compartment replacement, Battery Terminal: 步骤 13 中的图像 1,2 Sony Cyber-shot DSC-W5 battery compartment replacement, Battery Terminal: 步骤 13 中的图像 2,2
    • Remove the orange cable connecting the battery terminal to the motherboard.
  14. Sony Cyber-shot DSC-W5 battery compartment replacement: 步骤 14 中的图像 1,1
    • The battery terminal is now free from the board and can be slid out.
结论
5等其他人完成本指南。
Thomas
于04/14/10注册
133 声望
创作了6篇指南
团队
Cal Poly, Team 15-50, Garner Spring 2010 Cal Poly, Team 15-50, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G50
5 名成员
创作了12篇指南
一条评论
Clean the little nobs in the pattery-pack and problem solved! I also removed the black plastic ring that was on the +pole inside.
martinenjellie - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 61
总计 16,224
