跳转到主内容
Sony Cyber-shot DSC-W5 LCD Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-W5 LCD Screen Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 2,2
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 7 中的图像 1,3 Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 7 中的图像 2,3 Sony Cyber-shot DSC-W5 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
结论
4等其他人完成本指南。
Thomas
于04/14/10注册
133 声望
创作了6篇指南
团队
Cal Poly, Team 15-50, Garner Spring 2010 Cal Poly, Team 15-50, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G50
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 11,358
