当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
Remove the two 2.5mm Phillips #0 screws.
You may have to remove the screws with a pair of tweezers when the screws are almost out.
Turn the camera so the right side faces you.
Turn camera so that the front of the camera is facing you.
Pull the front casing directly away from the camera.
The right side panel may fall off when you take the front panel off.
Tilt top casing up and towards you.
Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
Flash capacitors are dangerous! Be extremely careful when removing the capacitor from the camera. You can get shocked BADLY!
Remove the flash capacitor from the lens assembly.
Carefully place the flash capacitor away from where you are working.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
