本指南有最近更改,您可查看未经巡查的最新版本。
简介
To remove the Lens assembly, you must have background knowledge about disassembling the camera. (See previous guides)
你所需要的
Find the hatch labeled "open" on the left side of the bottom of the camera.
Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
Remove the four 2.5mm Phillips #0 screws.
Turn the camera so the back is facing you.
Remove the 2.5mm Philips #0 screw at the top of the camera.
5等其他人完成本指南。
