跳转到主内容
Sony Cyber-shot DSC-W290 LCD Assembly Replacement
你所需要的
  1. Sony Cyber-shot DSC-W290 LCD Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 2 中的图像 1,1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Sony Cyber-shot DSC-W290 LCD Assembly Replacement, Outer Casing: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement, Outer Casing: 步骤 3 中的图像 2,2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 4 中的图像 1,3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 4 中的图像 2,3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 5 中的图像 3,3
    • Turn the camera so the right side faces you.
  6. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 6 中的图像 1,1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 7 中的图像 2,2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 8 中的图像 2,2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 9 中的图像 1,2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 9 中的图像 2,2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 10 中的图像 1,2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 10 中的图像 2,2
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Sony Cyber-shot DSC-W290 LCD Assembly Replacement, LCD Assembly: 步骤 11 中的图像 1,1
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 12 中的图像 1,2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 12 中的图像 2,2
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
  13. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 13 中的图像 1,2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 13 中的图像 2,2
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: 步骤 14 中的图像 1,1
    • Pull the LCD and its casing away from the rest of the camera.
结论
3等其他人完成本指南。
Evan Mayer
于10/05/10注册
336 声望
创作了5篇指南
团队
Cal Poly, Team 7-54, Amido Fall 2010 Cal Poly, Team 7-54, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G54
4 名成员
创作了16篇指南
2指南评论
where can i get a replacement screen but one that isn't that expensive~
jenna - 回复
At Step 13, when re-assembling, insert the large ribbon into the slot using fingers then seat as far in as possible by pushing on each side gently, using tweezers.
Christopher Bell - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 29
总计 7,035
