简介
Make sure you have all of the requisite tools on hand before beginning to replace the flash bulb.
  1. Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Slide the blue locking tab to release the battery. Slide the battery out of the camera.
    • Slide the blue locking tab to release the battery. Slide the battery out of the camera.
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
    • Turn the camera so the left side-panel faces you. (It says 5x Optical Zoom)
    • Remove the two 2.5mm Philips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
    • Turn the camera so the right side faces you.
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
    • Turn camera so that the front of the camara is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
    • This is what your camera should look like now that you have removed the casing from all sides.
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
    • Pull the LCD and its casing away from the rest of the camera.
    • Turn the camera so the back is facing you.
    • Remove the 2.5mm Philips #0 screw at the top of the camera.
    • Tilt top casing up and towards you.
    • Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
    • Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
    • Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
    • Pull the top of the camera off and turn it so the bottom is facing you.
    • Desolder the three connections from the bulb to the small circuit board.
    • Remove the excess solder using your soldering iron and desoldering wick.
    • Gently wiggle the flash bulb to remove it from the joints.
    • It may be necessary to use the soldering iron to heat up the joints as you pull it off.
结论
William Schill
于2010年10月04日注册
222 信誉积分
创作了3篇指南
团队
Cal Poly, Team 7-54, Amido Fall 2010 Cal Poly, Team 7-54, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G54
4 名成员
创作了8篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 15
总计 6,129
