跳转到主内容
Sony Cyber-shot DSC-W150 Back Casing Replacement
你所需要的
  1. Sony Cyber-shot DSC-W150 Back Casing Replacement, Back Casing: 步骤 1 中的图像 1,1
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
  2. Sony Cyber-shot DSC-W150 Back Casing Replacement: 步骤 2 中的图像 1,1
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
  3. Sony Cyber-shot DSC-W150 Back Casing Replacement: 步骤 3 中的图像 1,1
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
  4. Sony Cyber-shot DSC-W150 Back Casing Replacement: 步骤 4 中的图像 1,1
    • On the left side of the camera, remove the two silver screws using the screwdriver.
  5. Sony Cyber-shot DSC-W150 Back Casing Replacement: 步骤 5 中的图像 1,1
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
  6. Sony Cyber-shot DSC-W150 Back Casing Replacement: 步骤 6 中的图像 1,1
    • After detaching the back cover, carefully pull it off.
  7. Sony Cyber-shot DSC-W150 Back Casing Replacement: 步骤 7 中的图像 1,1
    • The back cover should now be separated from the camera.
结论
4等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 5,008
