跳转到主内容
Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement
你所需要的
  1. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Battery: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 2 中的图像 1,3 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 2 中的图像 2,3 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 2 中的图像 3,3
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Cover: 步骤 3 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 4 中的图像 1,3 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 4 中的图像 2,3 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 4 中的图像 3,3
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 5 中的图像 1,1
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 6 中的图像 1,1
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
  7. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: 步骤 7 中的图像 2,2
    • Remove the three 4mm length screws located on the inside of the front cover with the Phillips #00 screwdriver.
  8. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 步骤 8 中的图像 2,2
    • Wiggle sliding lens cover after all screws are removed and separate from front cover.
结论
Leslie Mundell
于03/18/15注册
411 声望
创作了4篇指南
团队
Michigan Tech, Team 1-8, Lauer Spring 2015 Michigan Tech, Team 1-8, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G8
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 677
