跳转到主内容
Sony Cyber-shot DSC-TX55 LCD Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Slide open the battery cover in the direction that the arrows on device are pointing.
    • Flip the blue battery lock to eject the battery.
    • Remove the battery from the device.
  2. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Using your Phillips #00 screwdriver, remove all four 0.3 cm screws that are located on both ends, as well as the bottom of your Cyber-Shot.
    • Make sure that your screws are placed on a flat, still surface so they do not roll away.
  3. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Gently pull away the back end of the camera where the LCD screen is located.
    • Remove the metal frame that is located around the LCD screen.
  4. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the front cover.
  5. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Gently remove the lens from the device.
    • The lens will hang on by the orange strips, be careful not to tug on the lens.
  6. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Gently slide the LCD screen using very light pressure to the right until it pops open.
  7. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • The LCD screen will open to the right.
    • Remove the orange tab from the device.
结论
2等其他人完成本指南。
Megan East
于10/13/15注册
555 声望
创作了5篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 30
总计 2,366
