跳转到主内容
Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement
你所需要的
  1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: 步骤 1 中的图像 3,3
    • Remove the battery
    • Remove the five 2.5mm Philips #0 screws.
    • Remove the one 2.5mm Philips #0 screw inside the HDMI case.
  2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 2 中的图像 1,1
    • Gently work and pull the front cover off of the camera
  3. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 3 中的图像 1,1
    • Gently pull and disconnect the ribbon cable connecting the front cover to the main body
  4. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 4 中的图像 1,3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 4 中的图像 2,3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    iSesamo Opening Tool
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
    • Take care of the tab/clip at the bottom, it can be a little tricky.
    • iSesamo Opening Tool is highly recommended
  5. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 5 中的图像 2,2
    • Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
  6. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 6 中的图像 1,3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 6 中的图像 2,3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
    • Note: where the adhesive strip is located.
    • Turn the device over and remove the clear tape and black tape.
    • Important: Save the clear and black tape, they will be used for the replacement unit.
  7. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 7 中的图像 1,1
    • Gently pull the small flat ribbon cable from the main body
    • In order to disconnect the large flat ribbon cable, you need to flip up the black ribbon clamp located on the main body where the socket is located
  8. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 步骤 8 中的图像 1,1
    • Reattach new display, and reconnect all components
    • Test camera to ensure the new screen is working
    • Congrats!
结论
另外一个人完成了本指南。
Tim
于03/12/12注册
2,217 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 4,850
