跳转到主内容
Sony Cyber-shot DSC-T9 CCD Module Replacement
你所需要的
  1. Sony Cyber-shot DSC-T9 CCD Module Replacement, Battery: 步骤 1 中的图像 1,1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 CCD Module Replacement: 步骤 2 中的图像 1,1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: 步骤 3 中的图像 3,3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 CCD Module Replacement: 步骤 4 中的图像 1,1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 CCD Module Replacement: 步骤 5 中的图像 1,1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 CCD Module Replacement: 步骤 6 中的图像 1,1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 CCD Module Replacement, CCD Module: 步骤 7 中的图像 1,1
    • This is the CCD module.
  8. Sony Cyber-shot DSC-T9 CCD Module Replacement: 步骤 8 中的图像 1,1
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  9. Sony Cyber-shot DSC-T9 CCD Module Replacement: 步骤 9 中的图像 1,1
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  10. Sony Cyber-shot DSC-T9 CCD Module Replacement: 步骤 10 中的图像 1,1
    • The CCD module is now removed from the camera.
结论
3等其他人完成本指南。
Stephannie Allen
于03/11/13注册
276 声望
创作了10篇指南
团队
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G1
4 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 1,116
