跳转到主内容
Sony Cyber-shot DSC-T9 Back Cover Replacement
你所需要的
  1. Sony Cyber-shot DSC-T9 Back Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-T9 Back Cover Replacement, Front Cover: 步骤 3 中的图像 3,3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 4 中的图像 1,1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 5 中的图像 1,1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 6 中的图像 1,1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 Back Cover Replacement, Back Cover: 步骤 7 中的图像 1,1
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 8 中的图像 1,1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 9 中的图像 1,3 Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 9 中的图像 2,3 Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 9 中的图像 3,3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 10 中的图像 1,3 Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 10 中的图像 2,3 Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 10 中的图像 3,3
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 11 中的图像 1,1
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 Back Cover Replacement: 步骤 12 中的图像 1,1
    • The back cover is now removed from the internal hardware.
结论
Stephannie Allen
于03/11/13注册
255 声望
创作了10篇指南
团队
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G1
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 572
