跳转到主内容
Sony Cyber-shot DSC-T9 AV Port Replacement
你所需要的
  1. Sony Cyber-shot DSC-T9 AV Port Replacement, Battery: 步骤 1 中的图像 1,1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 2 中的图像 1,1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 AV Port Replacement, Back Cover: 步骤 3 中的图像 1,1
    • This is the camera without the front cover.
  4. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 4 中的图像 1,1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  5. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 5 中的图像 3,3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  6. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 6 中的图像 1,3 Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 6 中的图像 2,3 Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 6 中的图像 3,3
    • Pull apart the inner hardware from the back case by prying on the left side.
  7. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 7 中的图像 1,1
    • Remove the back cover.
  8. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 8 中的图像 1,1
    • The back cover is now removed from the internal hardware.
  9. Sony Cyber-shot DSC-T9 AV Port Replacement, CCD Module: 步骤 9 中的图像 1,1
    • This is the CCD module.
  10. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 10 中的图像 1,1
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  11. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 11 中的图像 1,1
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  12. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 12 中的图像 1,1
    • The CCD module is now removed from the camera.
  13. Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: 步骤 13 中的图像 1,2 Sony Cyber-shot DSC-T9 AV Port Replacement, AV Port: 步骤 13 中的图像 2,2
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  14. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 14 中的图像 1,1
    • Remove metal screw plate.
  15. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 15 中的图像 1,1
    • Use pry stick to pop off ribbon.
  16. Sony Cyber-shot DSC-T9 AV Port Replacement: 步骤 16 中的图像 1,1
    • Remove AV port from camera.
结论
Stephannie Allen
于03/11/13注册
255 声望
创作了10篇指南
团队
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G1
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 604
