跳转到主内容
Sony Cyber-shot DSC-T500 LCD Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Case Screws: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Case Screws: 步骤 1 中的图像 2,2
    • There are 4 screws total holding the outer shell of the camera. One on each corner. To reach the bottom two, you have to slide the camera cover up. Vise versa for the top two.
    • Make sure to remove the battery before taking the camera apart.
  2. Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Back Panel: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Back Panel: 步骤 2 中的图像 2,2
    • Separate the front and back housings carefully.
    • Be careful not to pry it apart as they are connected together by the LCD ribbon cables.
    • Once you have separated the two housings unplug the LCD ribbon cables.
    • There should be three. One big one and two small ones
    • Remove the LCD screen from the housing.
    • You'll have to carefully lift the internal components of the camera in order to remove the LCD screen.
结论
Chelsea Vitone
于01/21/15注册
213 声望
创作了2篇指南
团队
UWT Liner: Group 4 UWT Liner: Group 4 的会员
Community
6 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 530
