Locate the cover on the bottom of the camera.
  • Locate the cover on the bottom of the camera.
  • Slide the cover towards the back of the camera.
  • Be careful—the battery can slide out on its own.
添加评论
Carefully remove the exposed battery.
  • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
添加评论
  • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
添加评论
  • Pull the two halves of the camera apart.
  • Place the two halves down with the insides facing you.
添加评论
  • Find the two clips holding the motherboard to the black lens box.
  • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
添加评论
  • After releasing the clips, pull out black lens box.
添加评论
  • Use the plastic opening tool to flip the clip.
添加评论
  • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
  • Pull out the flash.
添加评论
  • Use the plastic opening tool to release the clips.
添加评论
  • Flip the motherboard unit over.
添加评论
  • Pull the ribbon to separate the motherboard unit from the camera case.
添加评论
  • Use the #00 screwdriver to remove the 3mm screw located inside the white plastic piece.
添加评论
  • Remove the white plastic piece.
添加评论
  • Use the #00 screwdriver to remove the 3mm screw.
  • This is the back of the motherboard unit.
添加评论
  • The only thing holding the motherboard in are stationary clips.
  • Move the motherboard back and forth until it is loose and can be released from the motherboard unit.
添加评论
  • You are left with the motherboard unit (on the left) and actual detached mother board (on the right).
添加评论
结论
Rosario
于2012年04月12日注册
24 信誉积分
创作了3篇指南
团队
Cal Poly, Team 7-35, Maness Spring 2012 Cal Poly, Team 7-35, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G35
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 496
