跳转到主内容
Sony Cyber-shot DSC-T1 LCD screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-T1 LCD screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: 步骤 3 中的图像 3,3
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
  4. Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 4 中的图像 1,1
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 5 中的图像 1,1
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 6 中的图像 1,1
    • After releasing the clips, pull out black lens box.
  7. Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to flip the clip.
  8. Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 8 中的图像 2,2
    • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
    • Pull out the flash.
  9. Sony Cyber-shot DSC-T1 LCD screen Replacement, LCD screen: 步骤 9 中的图像 1,1
    • Use the plastic opening tool to flip the top clip that holds the ribbon to the motherboard unit.
  10. Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 10 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 10 中的图像 2,2
    • Flip the motherboard unit up to expose the metal plate beneath it.
    • Remove the four 3mm screws shown using the 00 screwdriver.
  11. Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 11 中的图像 1,1
    • Lift and remove the metal plate covering the LCD screen from the camera.
  12. Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 12 中的图像 1,3 Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 12 中的图像 2,3 Sony Cyber-shot DSC-T1 LCD screen Replacement: 步骤 12 中的图像 3,3
    • Flip the LCD over to the other side of the camera.
    • Peel the tape connecting the LCD to the camera.
    • Remove LCD screen
结论
另外一个人完成了本指南。
Paul Elrich
于04/12/12注册
33 声望
创作了2篇指南
团队
Cal Poly, Team 7-35, Maness Spring 2012 Cal Poly, Team 7-35, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G35
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 72
总计 3,294
