跳转到主内容
Sony Cyber-shot DSC-T1 LCD Replacement
你所需要的
  1. Sony Cyber-shot DSC-T1 LCD Replacement, Battery: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 3 中的图像 3,3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 4 中的图像 2,2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 LCD Replacement, CCD Sensor Module: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD Replacement, CCD Sensor Module: 步骤 5 中的图像 2,2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 6 中的图像 1,1
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 LCD Replacement, Motherboard Assembly: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD Replacement, Motherboard Assembly: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
  8. Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 8 中的图像 1,1
    • Remove the ribbon cables from these two ZIF connectors.
  9. Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 9 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 9 中的图像 2,2
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
  10. Sony Cyber-shot DSC-T1 LCD Replacement, LCD: 步骤 10 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD Replacement, LCD: 步骤 10 中的图像 2,2
    • Use a PH00 screwdriver to remove the 2.9 mm phillips screw on the upper left side of the case.
  11. Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 11 中的图像 1,2 Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 11 中的图像 2,2
    • Remove the back frame from the LCD assembly.
    • Turn the LCD assembly over and gently pull the top bar off (which has the shutter and power buttons).
  12. Sony Cyber-shot DSC-T1 LCD Replacement: 步骤 12 中的图像 1,1
    • Pull the tape off that holds the LCD to the assembly.
结论
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 30
总计 4,976
