跳转到主内容
Sony Cyber-shot DSC-T1 Flash Module Replacement
你所需要的
  1. Sony Cyber-shot DSC-T1 Flash Module Replacement, Battery: 步骤 1 中的图像 1,2 Sony Cyber-shot DSC-T1 Flash Module Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 Flash Module Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 3 中的图像 3,3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 Flash Module Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-T1 Flash Module Replacement: 步骤 4 中的图像 2,2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 Flash Module Replacement, CCD Sensor Module: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-T1 Flash Module Replacement, CCD Sensor Module: 步骤 5 中的图像 2,2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 Flash Module Replacement: 步骤 6 中的图像 1,1
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: 步骤 7 中的图像 1,3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: 步骤 7 中的图像 2,3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: 步骤 7 中的图像 3,3
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  8. Sony Cyber-shot DSC-T1 Flash Module Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-T1 Flash Module Replacement: 步骤 8 中的图像 2,2
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
结论
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 2,316
