跳转到主内容
Sony Cyber-shot DSC-T1 CCD chip Replacement
你所需要的
  1. Sony Cyber-shot DSC-T1 CCD chip Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 CCD chip Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 CCD chip Replacement, CCD chip: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-T1 CCD chip Replacement, CCD chip: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-T1 CCD chip Replacement, CCD chip: 步骤 3 中的图像 3,3
    • Locate and remove the 3mm screws on the bottom and sides of the camera with a JIS size #0 screwdriver.
  4. Sony Cyber-shot DSC-T1 CCD chip Replacement: 步骤 4 中的图像 1,1
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 CCD chip Replacement: 步骤 5 中的图像 1,1
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it up. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 CCD chip Replacement: 步骤 6 中的图像 1,1
    • After releasing the clips, pull out the black lens box.
    • If the black lens box does not come out, go back to the previous step and make sure you released the correct clips.
  7. Sony Cyber-shot DSC-T1 CCD chip Replacement: 步骤 7 中的图像 1,1
    • Locate and unscrew the two 3mm screws on the bottom of the black lens box with the JIS #0 screwdriver.
  8. Sony Cyber-shot DSC-T1 CCD chip Replacement: 步骤 8 中的图像 1,1
    • With the tweezers remove the black tape to detach the chip from the lens box.
  9. Sony Cyber-shot DSC-T1 CCD chip Replacement: 步骤 9 中的图像 1,2 Sony Cyber-shot DSC-T1 CCD chip Replacement: 步骤 9 中的图像 2,2
    • Grab the chip with your thumbs and carefully pull it off.
    • The copper tab will be glued to the lens box. Be careful not to rip it.
    • The attached copper ribbons are part of the CCD chip.
结论
3等其他人完成本指南。
Rosario
于04/12/12注册
48 声望
撰写一个指南
团队
Cal Poly, Team 7-35, Maness Spring 2012 Cal Poly, Team 7-35, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G35
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 48
总计 4,995
