当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Locate the battery door at the bottom of the camera.
Press down on the door and slide it back. The door will pop open.
Remove the battery from the door that you opened in the previous step.
There are two screws on the left and right sides of the camera, and two screws on the bottom.
Use a PH00 screwdriver and remove the six 2.9mm screws.
Use hands to gently pry the front casing away from the camera.
Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
The second picture shows what these tabs look like in their open positions.
Grasp the CCD Sensor Module and remove it.
取消:我没有完成这个指南。
2等其他人完成本指南。
与12其他贡献者
于07/07/10注册
2,101 声望
创作了39篇指南
徽章: 9
+ 6更多徽章
where I can buy it?
Francesco Cortese - 2023年6月12日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 47
总计 12,943
