简介
This guide will aid you in the process of replacing the battery.
  1. Locate the cover on the bottom of the camera.
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
    添加评论
  2. Carefully remove the exposed battery.
    • Carefully remove the exposed battery.
      • If it is difficult to remove, flip over the camera and the battery will slide out.
    添加评论
结论
Rosario
于2012年04月12日注册
24 信誉积分
创作了3篇指南
团队
Cal Poly, Team 7-35, Maness Spring 2012 Cal Poly, Team 7-35, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G35
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 470
