跳转到主内容
Sony Cyber-shot DSC-P9 Top Button Replacement
你所需要的
  1. Sony Cyber-shot DSC-P9 Top Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 2 中的图像 1,1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 3 中的图像 2,2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Top Button Replacement, Outer Casing: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-P9 Top Button Replacement, Outer Casing: 步骤 4 中的图像 2,2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 5 中的图像 2,2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 6 中的图像 2,2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 7 中的图像 1,1
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Top Button Replacement, Top Button: 步骤 8 中的图像 1,1
    • Remove the 3.0mm Phillips #000 screw above the battery door on the side of the camera.
  9. Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 9 中的图像 1,1
    • Pull off the pieces of casing located on either side of the top button of the camera.
    • Both of the two pieces should slide off very easily. Do not force them off.
  10. Sony Cyber-shot DSC-P9 Top Button Replacement: 步骤 10 中的图像 1,1
    • Remove the top button piece. You will need to detach a small blue ribbon cable before the button can be fully removed.
结论
Andrew Forster
于04/16/12注册
12 声望
创作了2篇指南
团队
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G25
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 699
