跳转到主内容
Sony Cyber-shot DSC-P9 Outer Casing Replacement
你所需要的
  1. Sony Cyber-shot DSC-P9 Outer Casing Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 步骤 2 中的图像 1,1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-P9 Outer Casing Replacement: 步骤 3 中的图像 2,2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Outer Casing Replacement, Outer Casing: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-P9 Outer Casing Replacement, Outer Casing: 步骤 4 中的图像 2,2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-P9 Outer Casing Replacement: 步骤 5 中的图像 2,2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-P9 Outer Casing Replacement: 步骤 6 中的图像 2,2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Outer Casing Replacement: 步骤 7 中的图像 1,1
    • After the casing is removed, the camera should look as shown.
结论
另外一个人完成了本指南。
Jenna Crawford
于04/09/12注册
50 声望
创作了3篇指南
团队
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G25
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 9
总计 781
