跳转到主内容
Sony Cyber-shot DSC-P9 Lens Replacement
你所需要的
  1. Sony Cyber-shot DSC-P9 Lens Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 2 中的图像 1,1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 3 中的图像 2,2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: 步骤 4 中的图像 2,2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 5 中的图像 2,2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 6 中的图像 2,2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 7 中的图像 1,1
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Lens Replacement, Lens: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-P9 Lens Replacement, Lens: 步骤 8 中的图像 2,2
    • Dislodge the round casing from the lens.
    • Pull it away from the rest of the camera.
  9. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 9 中的图像 1,1
    • Unscrew the two 4.0mm Phillips #000 screws from the display.
  10. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 10 中的图像 1,1
    • Pull the two ribbon cables out of their slots on the back circuit board.
  11. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 11 中的图像 1,1
    • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
  12. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 12 中的图像 1,3 Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 12 中的图像 2,3 Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 12 中的图像 3,3
    • Work the back panel out from under the small grey clip.
    • Slide the back panel off of the camera by dislodging it from the remaining clips.
    • Below is a flat, orange cable connecting the lens to the motherboard.
    • Be careful not to bend the back plate during this process.
  13. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 13 中的图像 1,1
    • Turn the camera over so that you can see the front of the lens.
    • Two connectors link the lens to the motherboard.
    • Gently bring the lens away from the camera.
  14. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 14 中的图像 1,1
    • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
    • Be careful not to exert too much force, as the connectors are delicate.
  15. Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 15 中的图像 1,3 Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 15 中的图像 2,3 Sony Cyber-shot DSC-P9 Lens Replacement: 步骤 15 中的图像 3,3
    • Gently pull out the cables and move the lens away from the rest of the camera.
    • You should now have two distinct, separate components.
结论
另外一个人完成了本指南。
Sean Sayles
于05/09/12注册
7 声望
撰写一个指南
团队
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G25
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,352
