当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Slide the battery latch down the side of the camera with your hands.
The latch will automatically pop open.
Unlatch the clip over the battery.
The battery will partially pop out.
Remove the battery from the camera.
Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
Pull the back case gently away from the rest of the camera.
Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
Unlatch the display by sliding it towards the circuit board.
Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
Be careful not to rip the ribbon cables while disconnecting them.
The LCD is now separated from the camera.
取消:我没有完成这个指南。
与6其他贡献者
于04/09/12注册
50 声望
创作了3篇指南
徽章: 7
+ 4更多徽章
CPSU-AMIDO-S12S17G25
4 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 20
总计 905
