跳转到主内容
Sony Cyber-shot DSC-P9 LCD Replacement
你所需要的
  1. Sony Cyber-shot DSC-P9 LCD Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 2 中的图像 1,1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 3 中的图像 2,2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 LCD Replacement, LCD: 步骤 4 中的图像 1,1
    • Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
  5. Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 5 中的图像 2,2
    • Pull the back case gently away from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 6 中的图像 1,1
    • Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
  7. Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 7 中的图像 2,2
    • Unlatch the display by sliding it towards the circuit board.
  8. Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 8 中的图像 1,1
    • Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
    • Be careful not to rip the ribbon cables while disconnecting them.
  9. Sony Cyber-shot DSC-P9 LCD Replacement: 步骤 9 中的图像 1,1
    • The LCD is now separated from the camera.
结论
Jenna Crawford
于04/09/12注册
50 声望
创作了3篇指南
团队
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G25
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 886
