简介
This guide explains how to replace the viewfinder in the Sony Cybershot DSC-P52
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Open the memory card compartment.
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Pull apart the front and back cover pieces carefully.
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Open the case as shown.
    • Open the case as shown.
  6. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  7. Unclip the clip holding the ribbon cable in.
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  8. Pull the ribbon cable out.
    • Pull the ribbon cable out.
  9. Remove the two additional screws on the back of the lens.
    • Remove the two additional screws on the back of the lens.
  10. Detach the ribbon cables and unplug the cable leading to the back of the motherboard.
    • Detach the ribbon cables and unplug the cable leading to the back of the motherboard.
  11. Remove the motherboard and the flash from the rest of the hardware.
    • Remove the motherboard and the flash from the rest of the hardware.
  12. Remove the screw indicated in the picture to detach the lens and the  viewfinder from the other hardware.
    • Remove the screw indicated in the picture to detach the lens and the viewfinder from the other hardware.
  13. Remove the three screws shown to separate the lens from the viewfinder.
    • Remove the three screws shown to separate the lens from the viewfinder.
  14. Purchase a new viewfinder.
    • Purchase a new viewfinder.
    • Repeat the previous steps in reverse order to rebuild.
结论
Kari Johnson
于2011年01月10日注册
127 信誉积分
创作了2篇指南
团队
Cal Poly, Team 3-43, Regan Winter 2011 Cal Poly, Team 3-43, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G43
4 名成员
创作了10篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 2,010
