跳转到主内容
Sony Cyber-shot DSC-P52 Outer Case Replacement
你所需要的
  1. Sony Cyber-shot DSC-P52 Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Outer Case Replacement: 步骤 2 中的图像 1,1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Outer Case Replacement: 步骤 3 中的图像 1,1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Outer Case Replacement: 步骤 4 中的图像 1,1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Outer Case Replacement: 步骤 5 中的图像 1,1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Outer Case Replacement: 步骤 6 中的图像 1,1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Outer Case Replacement: 步骤 7 中的图像 1,1
    • Pull the ribbon cable out.
结论
Trevor
于01/20/11注册
295 声望
创作了6篇指南
团队
Cal Poly, Team 3-43, Regan Winter 2011 Cal Poly, Team 3-43, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G43
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 569
