当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
Open the battery compartment and remove the batteries.
Remove all of the visible screws on the outside of the case.
There should be three of them that are all easily located.
Pull apart the front and back cover pieces carefully.
The front cover should come completely free with little effort.
The back cover will still be attached to the circuit board.
Remove all six screws on the front side of the motherboard circled in the picture.
Pull the motherboard from the rest of the housing.
It will still be connected to the flash unit.
Detach the ribbon cables shown.
Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
Remove the flash unit from the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
