跳转到主内容
Sony Cyber-shot DSC-P52 LCD Replacement
你所需要的
  1. Sony Cyber-shot DSC-P52 LCD Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 2 中的图像 1,1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 3 中的图像 1,1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 4 中的图像 1,1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 5 中的图像 1,1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 6 中的图像 1,1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 7 中的图像 1,1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 LCD Replacement, Sony Cyber-shot DSC-P52 Removing Ribbon Cables: 步骤 8 中的图像 1,1
    • Unclip the ribbon cable shown the in picture.
    • Some ribbon cables do not have a clip holding them in.
  9. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 9 中的图像 1,1
  10. Sony Cyber-shot DSC-P52 LCD Replacement, LCD: 步骤 10 中的图像 1,1
    • Remove 7 Screws to remove plate and expose LCD screen.
  11. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 11 中的图像 1,1
    • Remove LCD plate to expose LCD components and ribbon cables
  12. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 12 中的图像 1,1
    • Check connection of LCD to cables
    • If cables are intact, disconnect cables and replace LCD with new part
  13. Sony Cyber-shot DSC-P52 LCD Replacement: 步骤 13 中的图像 1,1
    • Repeat steps in reverse order to reassemble the camera
结论
Mark
于01/11/11注册
13 声望
撰写一个指南
团队
Cal Poly, Team 3-43, Regan Winter 2011 Cal Poly, Team 3-43, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G43
4 名成员
创作了20篇指南
一条评论
I don’t know the cause of my camera not turning on.
Smgmc64 Productions - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,483
