跳转到主内容
Sony Cyber-shot DSC-P100 LCD Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-P100 LCD Screen Replacement, Back Casing: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-P100 LCD Screen Replacement, Back Casing: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-P100 LCD Screen Replacement, Back Casing: 步骤 1 中的图像 3,3
    • Remove the four screws from the casing.
  2. Sony Cyber-shot DSC-P100 LCD Screen Replacement: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-P100 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Carefully pull the back casing away from the camera.
  3. Sony Cyber-shot DSC-P100 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,1
    • Using a pry tool, gently pry the top right corner of the LCD screen. Pry the screen until the four tabs release it from its current position.
  4. Sony Cyber-shot DSC-P100 LCD Screen Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-P100 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Push the metal tab on the right side of the screen until the plate underneath the LCD screen is released.
  5. Sony Cyber-shot DSC-P100 LCD Screen Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-P100 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Unfold the LCD screen and the plate underneath.
    • Now visible are the ribbon cables holding the screen and plate in place.
  6. Sony Cyber-shot DSC-P100 LCD Screen Replacement: 步骤 6 中的图像 1,3 Sony Cyber-shot DSC-P100 LCD Screen Replacement: 步骤 6 中的图像 2,3 Sony Cyber-shot DSC-P100 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Remove the LCD screen plate by gently pulling upward on the ribbon cable until the screen is removed from the camera.
结论
另外一个人完成了本指南。
Katie McCraw
于03/09/12注册
191 声望
创作了7篇指南
团队
Clemson, Team 1-5, Benson Spring 2012 Clemson, Team 1-5, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G5
4 名成员
创作了14篇指南
2指南评论
Hello!
Thank you for this tutorial.
I just disassembled a Sony DSC P1 (3Mega pixel).. And i would like to ask you if you knew if we may reuse the screen, or the sensor, or other components, in a different set up. Can we access the technical documentations of the inside components of sony's cameras? My intention would be for example to use the sensor with another lens and make another board ? Maybe im just too ambitious..
Thank you very much for your answer.
junkymilk - 回复
I have a question in regards to this camera. My wife has had one for years and then all of a sudden it started beeping and said something on the screen about the memory card that was inside. Does this mean the card with all the photos is bad? Maybe installing a new card would make this camera usable again? Thank you.
Ronald Mountin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 2,231
