跳转到主内容
Sony Cyber-shot DSC-P100 Camera Lens Replacement
你所需要的
  1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: 步骤 1 中的图像 3,3
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 2 中的图像 1,1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 3 中的图像 1,1
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 4 中的图像 2,2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: 步骤 5 中的图像 3,3
    • Remove the four screws from the casing.
  6. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 6 中的图像 2,2
    • Carefully pull the back casing away from the camera.
  7. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: 步骤 7 中的图像 1,2 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: 步骤 7 中的图像 2,2
    • Remove the two screws on the back side of the camera surrounding the LCD screen.
  8. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 8 中的图像 1,3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 8 中的图像 2,3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 8 中的图像 3,3
    • Remove the two ribbon traces found on the left side of the lens on the front of camera holding the lens in place.
    • Carefully pull the lens away front the camera until it is released.
  9. Sony Cyber-shot DSC-P100 Camera Lens Replacement: 步骤 9 中的图像 1,1
    • The lens is now successfully removed from the camera.
结论
另外一个人完成了本指南。
Katie McCraw
于03/09/12注册
191 声望
创作了7篇指南
团队
Clemson, Team 1-5, Benson Spring 2012 Clemson, Team 1-5, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G5
4 名成员
创作了14篇指南
一条评论
Is there a way to disassemble the lens to correct the alignment. My daughter dropped it and I think the mechanism has been misaligned.
Macjune Tolentino - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 2,694
