当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
First locate the appropriate screws for detachment.
Remove the five screws shown using a Phillips #00 Screwdriver.
It is important to put the small screws in a safe location in order to reassemble the casing.
Using a spudger, carefully pry open the front casing.
Carefully separate the front casing from the camera body.
CAUTION: Be careful not to break the wire connecting the front casing and the camera.
Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
Using a spudger, pry the small latch between the lens and the flash open to release the flash.
Pull the flash away from the camera.
取消:我没有完成这个指南。
与5其他贡献者
于03/09/12注册
191 声望
创作了7篇指南
徽章: 8
+ 5更多徽章
CLEM-BENSON-S12S1G5
4 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 29
总计 2,509
