跳转到主内容
Sony Cyber-shot DSC-HX90V Button Board Replacement
你所需要的
  1. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: 步骤 1 中的图像 3,3
    • Remove the marked screw with a Phillips #000 screwdriver.
    • Remove the marked black M1.4 X 3.5 Phillips head screws
    • Use the spudger to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: 步骤 2 中的图像 1,3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: 步骤 2 中的图像 2,3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: 步骤 2 中的图像 3,3
    • After removing the marked black M1.4 X 3.5 Phillips head screws with the Phillips #000 screwdriver on the side panel, using the spudger where the red arrow marks, insert and gently remove the side panel from the device.
    • From either corner of the button board gently use hands to remove the button board.
  3. Sony Cyber-shot DSC-HX90V Button Board  Replacement: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • After the outer black panel case of button is removed, gently disconnect the control board data cable to the motherboard utilizing the tweezers gently where the red arrow marks.
    • Ribbon wires can easily be damaged.
结论
Marin Rusinov
于02/02/17注册
853 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 34
总计 2,076
