跳转到主内容
Sony Cyber-shot DSC-HX80 LCD Screen Replacement
你所需要的
  1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
  2. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Open the compartment located at the bottom of the camera. Slide the LOCK/OPEN switch to the OPEN side. Locate the small blue tab on the side. Pull it in direction away from battery. Remove the battery and set it aside.
  3. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Flip LCD screen upwards.
    • Use the PH000 Phillips head screwdriver to remove the two 0.3 mm Phillips black screws located on the sides of the LCD screen. Place screws on magnetic mat or plastic bag.
  4. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Use the PH000 Phillips head screwdriver to remove the two additional 0.3 mm black Phillips screws located on the top edge of the LCD screen. Place screws on magnetic mat or plastic bag.
  5. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Use a nylon spudger to gently remove the damaged LCD screen off the camera.
    • Replace LCD screen with new one.
结论
4等其他人完成本指南。
Gordon Jones
于10/02/18注册
1,081 声望
创作了5篇指南
团队
7指南评论
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Dale Bjerning - 回复
Hello could you show a picture of where exactly under the flash has to be the magnetite tangle. Thanks.
Wolfina -
Anyone know where I can find the cable from the screen to the camera?
Thorusofer Dragon Knight - 回复
same question here! i repalced the lcd thinking that was the problem but the lcd is still black. the viewfinder works fine so i think i need to replace the cable that goes from the camera to the screen. any info?
Facundo V -
where can i find the screen other then threw sony
ninjadawn25 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 62
总计 4,537
