跳转到主内容
Sony Cyber-shot DSC-HX300 View Finder Replacement
你所需要的
  1. Sony Cyber-shot DSC-HX300 View Finder Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 2 中的图像 1,1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 3 中的图像 1,1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 4 中的图像 2,2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: 步骤 5 中的图像 3,3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Philips head screws holding the plastic camera housing together. They are located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down and remove the remaining 3 (4 cm) Phillips head screws holding the plastic housing together.
  6. Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 6 中的图像 2,2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 7 中的图像 1,1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 8 中的图像 1,2 Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 8 中的图像 2,2
    • Remove the 1 (2 cm) Phillips head screw
    • Remove the 2 (5 cm) Phillips head screws that mount the View Finder to the camera.
    • Carefully disconnect the ribbon wire that connects the View Finder to the Motherboard.
  9. Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 9 中的图像 1,2 Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 9 中的图像 2,2
    • Gently pull the plastic View Finder off of the metal mounting bracket.
  10. Sony Cyber-shot DSC-HX300 View Finder Replacement: 步骤 10 中的图像 1,1
    • The replacement View Finder can now be installed.
结论
另外一个人完成了本指南。
Elizabeth Surface
于08/26/15注册
1,465 声望
创作了9篇指南
团队
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 的会员
USFT-MEIER-F15S4G6
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 1,204
