跳转到主内容
Sony Cyber-shot DSC-HX300 Motherboard Replacement
你所需要的
  1. Sony Cyber-shot DSC-HX300 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
  6. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 8 中的图像 1,3 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 8 中的图像 2,3 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
  9. Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 9 中的图像 1,2 Sony Cyber-shot DSC-HX300 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
结论
Elizabeth Surface
于08/26/15注册
1,465 声望
创作了9篇指南
团队
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 的会员
USFT-MEIER-F15S4G6
4 名成员
创作了18篇指南
3条评论
During my vacation two capicators on the motherboard failed and 'exploded'.
I've ordered the motherboard and replaced it exactly as described here. Thanks for the explanation!
But since I've replaced it, I have autofocus problems, the camera isn't capable to focus, especially in wide zoom.
Is this something that needs to be calibrated or something?
Erik Mourik - 回复
Where can you order a motherboard?
Astrid - 回复
That ist what i need to know too. Where can i order a Motherboard?
Jürgen Frömmert - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 2,784
