跳转到主内容
Sony Cyber-shot DSC-HX300 Battery Replacement
  1. Sony Cyber-shot DSC-HX300 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 Battery Replacement: 步骤 2 中的图像 1,1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 Battery Replacement: 步骤 3 中的图像 1,1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 Battery Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-HX300 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the battery.
结论
To reassemble your device, follow these instructions in reverse order. Make sure to not skip a step as it will not work correctly if there was an error in reassembling the camera.
另外一个人完成了本指南。
Elizabeth Surface
于08/26/15注册
1,465 声望
创作了9篇指南
团队
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 的会员
USFT-MEIER-F15S4G6
4 名成员
创作了18篇指南
一条评论
How to replace the internal battery?
Neptue - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 28
总计 3,105
