简介
To take out and replace the lens assembly, you must first completely remove the central motherboard and all other internal components.
你所需要的
Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
I want to know which typa of battery used in DSC -H1 don't cyber shot
Which type of battery used in DSC H1
Close the battery cover by pushing the cover inwards and sliding it to the left to allow more maneuverability when disassembling other parts of the camera.
Using the plastic opening tool, pry apart the bottom of the camera at the line between the four removed screws.
Place the camera on its lens and use the plastic opening tool to pry at the crack in the case on all four sides of the camera.
Apply moderate force to the backside of the camera enclosure until the two pieces separate.
Remove the #00 4.0 mm Phillips screw and the #00 6.0 mm Phillips screw holding the motherboard to the front enclosure.
Disconnect the eight ribbon cables from their ports on the motherboard.
There's one more screw to remove under the ribbon cable top left.
Unscrew the #00 6.0 mm Phillips screw on the left side of the lens.
4等其他人完成本指南。
2条评论
Hi!
Very good tutorial, thanks a lot.
I have a question : after reassembling the device, do you need to do some kind of adjustment or is it "simply plug-and-play"?
Best regards,
Marin
Muy bueno el tutorial felicitaciones, sin embargo faltaron tornillos por nombrar, saludos
